It is currently Tue Aug 12, 2025 12:58 pm
 Post subject: neck angle Cracked
PostPosted: Tue Feb 09, 2016 2:33 am
First name: herry
Last Name: trismono
City: malang
State: east java
Zip/Postal Code: 65142
Country: Indonesia
Hi. Olfers I need help for my neck or headstock cracked. This cracked for second time. First time cracked I use CA glue. And this time I want to try Titebond. But I want to know why that headstock not enought to hold the strings? This EUB guitar I uses weedwacker string. And I need your suggestion for this problem. Thank's so much
 Post subject: Re: neck angle Cracked
PostPosted: Tue Feb 09, 2016 4:53 am
At a glance, it looks like a large stress riser across a very short cross section of end grain with little support.
Basically a sort of short half lap/butt joint? There's no strength in the end grain south of the peg box, and only a short lap in the upper part of the neck.
It's such a short length, especially the peg box side of the joint, I'm not even sure that Ebony or CF bars and epoxy would offer enough reinforcement, although certainly more than the original joint.
PostPosted: Tue Feb 09, 2016 1:18 pm
Last Name: Lloyd
Short of making a new neck. I would try a couple of dowels.
Michael Lloyd
PostPosted: Tue Feb 09, 2016 3:21 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I cannot seem to understand what I am looking at.
But, CA was by far the wrong choice. Regular Tite Bond and some clamps. Dowels if you have the ability.
These users thanked the author Mike OMelia for the post: Shaw (Tue Feb 09, 2016 4:44 pm)
PostPosted: Tue Feb 09, 2016 5:49 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
The big red thing to the right is a scroll bass headstock. The thing on the left is the back of the neck, with the truss rod nut sticking out the top. It took me a while for the perspective to make sense, too.
Yeah, dowels, I guess. Watch out for the truss rod slot and the rod itself.
PostPosted: Tue Feb 09, 2016 6:26 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Ya'll think Tite Bond will work over wood saturated with CA?
And what is that fiber looking stuff? Double sided tape? Fiberglass?
PostPosted: Wed Feb 10, 2016 4:07 am
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
thank you so much, I will try with titebond and add the dowell too.
GBU
PostPosted: Wed Feb 10, 2016 4:10 am
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
Hi, Colin I just built from the plan. thank's.
PostPosted: Wed Feb 10, 2016 5:29 am
Yes Harry, it wasn't a dig at you at all.
I remember seeing your earlier posts, you built from the The Libellula plans on Mottola's site.
Doesn't mean its not a high stress type of joint.
The lap section which broke twice is only about 3/4" long on the plans, and the pegbox section 1/2".
Not a whole lot of wood for the stress on and /weight of the pegbox.
PostPosted: Wed Feb 10, 2016 9:00 am
Unless you can remove the glue "residue 100%" (I think impossible in the case of CA) PVA glue will not work properly, it has to saturate the open wood pores. I would suggest the dowels and a high strength Epoxy.
Ken Cierp
